rear end id help - NCRS Discussion Boards
rear end id help
  • Ken B.
    • May 31, 2006
    • 233
    rear end id help
    Got the numbers off my rear end and not sure what they mean.LRW126E1..I do know the LR is 3:36 posi..Any help on the others will be awesome.Thanks
    Ken
    • 43273
    Re: rear end id help
    Ken
    Ken------
    "W"= Warren Gear and Axle plant (where all 63-79 Corvette carriers were assembled)
    "126"= 126th day of the year
    "E"= Eaton posi unit (all 65-79 Corvettes with posi used Eaton units)
    "1"= 1st shift
    • Joe W.
      • March 1, 2000
      • 88
      Just out of curiosity,
      where exactly on the rear end are the codes found?
      I have yet to research this on my car.
      Thanks.
      Joe
      • Ken B.
        • May 31, 2006
        • 233
        Thanks.
        Joe
        on the bottom surface of the carrier at the cover mounting flange..I used a steel brush to clean it up then a mirror and flash light to see them.
          Joe -
          Here's a photo of where you'll find the numbers - between the spring mounting plate and the strut rod bracket.
          • Joe W.
            • March 1, 2000
            • 88
            Thank you Mr. Hinckley!
