Tire Mileage - NCRS Discussion Boards
Tire Mileage
  • Kevin G.
    • February 1, 2005
    • 1077
    Tire Mileage
    Under "normal" driving conditions can anyone guess-ti-mate how many miles I can expect to get out of a set of repro Firestone Wide Oval tires? I was wondering how they would compare to the newer radials.
    Kevin
    • 15706
    Re: Tire Mileage
    Back when they came out 10K was about it. Typical low speed rated, hard compound radials that guys run today should be good for at least 40K and up to 80K, so most will not wear out. Even the Z-rated Pirelli P4000 should go 30-40K.
    The above assumes normal road driving and no serious alignment problems.
    • Kevin G.
      • February 1, 2005
      • 1077
      Re: Tire Mileage
      Thanks Duke,
      That's what I thought! Are the current repros made similarly to he older tires? In other words just as soft as originals? Yes, I was trying to say that no smokey burnouts and good alignment would be "normal".
      Kevin
        • 15706
        Re: Tire Mileage
        I have no idea about current repro tire compounds, other than they are likely different than original.
        AFAIK repro tires must have UTQG ratings, so compare the wear rating to typical radials that are used today.
          • 3418
          Re: Tire Mileage
          Kevin,
          If you're asking that question, that BLUE car must REALLY be a 'daily driver'.
          GOOD FOR YOU!!!!!!
          • Kevin G.
            • February 1, 2005
            • 1077
            Re: Tire Mileage
            Kevin,
            GOOD FOR YOU!!!!!!
            Every day! No comparison in mpg to my F250 V10 See you soon!
            Kevin
