2 questions - NCRS Discussion Boards
2 questions
+ More Options
Posts
  • Rex T.
    • December 1, 1984
    • 455
    2 questions
    Is there a "for sure" way to tell if a 67 gas lid is original or repro? Also, who makes the most accurate and reliable temp sending unit for a 67 big block?
    Thanks in advance for your help. Rex
  • Rex T.
    • December 1, 1984
    • 455
    Re: 2 questions
    TTT please..................
    Rex
    • Elio M.
      • June 30, 2003
      • 2
      Re: 2 questions
      The size of the dimple on the back plate is a usual giveaway. It is much larger on the reproductions. Also the spot welds are different.
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Re: 2 questions
        Also, originals will have two sets of part numbers cast in the same plain onto the hinge. Current replacements will have only a single set or a double set that is stacked.
        HaND
        • Paul L.
          • November 1, 2002
          • 1414
          Re: 2 questions
          I believe this is an original. Numbers (side-by-side) are 38144041 30181-H.
