C-2 Ammeter - NCRS Discussion Boards
C-2 Ammeter
+ More Options
Posts
  • Larry S.
    • September 19, 2007
    • 204
    C-2 Ammeter
    I have tested my ammeter (in the dash) with a 1.5 Volt battery and there is no needle movement at all. I think that I will have to take it out and either rebuild it or replace it. QUESTION: Must I remove the gauge cluster to get it out of the dash (1966 C-2) , or if I remove the 3 nuts on the bolts on the back of the amp gauge, will it come out of the dash?
    If I must remove the cluster, what is the easiest(and best) method?
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: C-2 Ammeter
    Larry -- if memory serves, eons ago, I was able to remove the mini-pod of fuel gauge and ammeter by undoing the 3 screws that hold it to the main cluster, then removing those 2 instruments as a sub-assy. Might help if you remove the headlight switch before, for access.
    I'm sure if this is impossible, others will chime in.
    • William C.
      • May 31, 1975
      • 6037
      Re: C-2 Ammeter
      Done it myself, just as described, as dash work goes, not one of the more difficult jobs. I think I remember it being done by one member on a PV!
      Bill Clupper #618
      • Larry S.
        • 204
        Re: C-2 Ammeter
        Thanks for the info. I will remove the ignition switch after I have a closer look at the back of the gauge cluster.
        • Larry S.
          • 204
          Re: C-2 Ammeter
          OOps ! I meant to say, the headlight switch !
          Larry
