66 A arms - NCRS Discussion Boards
66 A arms
  • Tony C.
    • February 29, 2008
    • 117
    66 A arms
    How long are the long nuts that holds the cross shaft and the shims at the upper A arms.
    Thanks Tony
    • 43219
    Re: 66 A arms
    Thanks Tony
    Tony-----
    How long are the long nuts...? Well, let's put it this way to cover all bases: the BOLTS that retain the upper control arm shaft to the frame were 2-1/4" long. They were a special bolt with knurled upper shank, phosphate or black oxide finished and 7/16-20 thread. They were GM-discontinued more than 25 years ago.
    The NUT that threads onto the bolt and clamps the assembly was a 7/16-20 stover-type lock nut. It was zinc finished and 3/8" thick.
