Wheel Scuff - NCRS Discussion Boards
Wheel Scuff
  • David J.
    • August 19, 2007
    • 65
    Wheel Scuff
    Much to my chagrin and embarrassment, I have put a scuff on the edge of the polish chrome wheel on my '05. The scuff is about an inch and one half long along the edge of the wheel where it meets the tire. I am hoping that there may be a way to buff out the scuff. I haven't dealt with a problem like this before, so I would appreciate some advice. Thanks. Dave
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Wheel Scuff
    there is no way to remove the scuf as the wheel must be refinished. try these people or someone like them. http://www.wheelcollision.com/index.html . i understand most dealerships have a contact in the area that can refinish the wheels
    • David J.
      • August 19, 2007
      • 65
      Re: Wheel Scuff
      Clem, thanks for the contact. I am about 75 minutes south of Bath so that might be a good option. Have you used the company you recommended in your post? Dave
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Wheel Scuff
        not personally as i have never scuffed a wheel BUT several people i know have used them with good results.
        • David J.
          • August 19, 2007
          • 65
          Re: Wheel Scuff
          I inadvertently identified the scuffed wheel as polished chrome and, in fact, it is polished aluminum. It doesn't make things better but I am hoping the repair may be easier. Any additional advice?
          • Harry S.
            • July 31, 2002
            • 5330
            Re: Wheel Scuff
            I think it's gonna cost ya about $200.00.
            Can you live with the curb rash, I don't see mine anymore, but it's there.
            Harry
            • David J.
              • August 19, 2007
              • 65
              Re: Wheel Scuff
              Thanks for the info, Harry. It is a small rash but, like you, I know it is there. $200 sounds like a just punishment for my carelessness. Dave
                • 43247
                Re: Wheel Scuff
                David-----
                One can do a pretty good job "erasing" small curb scuff marks from an ALUMINUM wheel. It takes care and "finesse" using very fine grit wet and dry sandpaper to remove the scuff. Then, after polishing the sanded area, apply clearcoat which is available in spray cans. It won't appear like it's never been touched, but, if done with enough care and patience, it will be about 90% improved.
                  • 43247
                  Re: Wheel Scuff
                  David-----
                  With a CHROMED aluminum wheel, there is no option but to have it professionally re-finished. I would not be surprised, though, if it costs more than $200.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    Re: Wheel Scuff
                    i understand that dealers have a person that comes to their dealership with a mobile shop that can refinish the wheels on the spot. check with your dealer
                    • Bill W.
                      • March 1, 1980
                      • 2000
                      Re: Wheel Scuff
                      I deal with wheel refinish people every day . if is small I would live with it. touch it up with some clear so it wont turn black. You wont be happy with a high polished refinished wheel .& i have seen lots of them....Bill
                      • David J.
                        • August 19, 2007
                        • 65
                        Re: Wheel Scuff
                        Joe, thanks for the tip. While the "rash" appears to be fairly superficial, I was not sure if it would be possible to smooth it out without making the situation worse. It sounds like your idea is worth a try. Again, I appreciate your expertise. Dave
                        • David J.
                          • August 19, 2007
                          • 65
                          Re: Wheel Scuff
                          Thanks, Bill. It does worry me that the fix may be more noticeable than the scuff. It is always tough to know what to do. Unfortunately, I am the type where these things really bother me; especially, when it is due to my own carelessness. It sounds like you have had some experience with this....thanks for your input. Dave
