67 TR vs RBW Valve Cover Bolts - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    I have a 327/300 hp 67. The catalogs call for RBW bolts for my valve cover while the JG only mentions TR. Will the correct "RBW" bolts judge as no deduction? Thanks.
    Kirk
  • Kirk M.
    • June 30, 2006
    • 1036
    Re: 67 TR vs RBW Valve Cover Bolts
    Any help on this guys!??
      • November 30, 1997
      Kirk -
      My '67 300 has eight RBW bolts, but I don't know that they're original - I've only owned it for six years.
      • Joe R.
        • February 28, 2002
        • 1356
        TR and RBW are both "period correct" suppliers for a 67 Corvette. Since GM used multiple vendors for most bolts, I don't see how any judge could justify a deduction for either head mark.
        • Kirk M.
          • June 30, 2006
          • 1036
          I had RBW's on the covers, but they were recessed heads, which I now know was not correct. At least I think?
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1463
            Right Kirk, the original cap screw heads were not recessed.
            Yours could be the pan bolts.
            HaND
            • Timothy B.
              • April 30, 1983
              • 5177
              Kirk,
              On my 67, the valve cover bolts have a small L and are not indented head, I believe these to be original.
              • Kirk M.
                • June 30, 2006
                • 1036
                Originally posted by Timothy Barbieri (6542)
                Kirk,
                Tim, that is EXACTLY what was on my car when I got it. I assumed they had been changed out at some point for the "correct" TR/RBW bolts. Are "L" bolts considered "correct" for NCRS judging? Thanks.
                Kirk
                • Timothy B.
                  • April 30, 1983
                  • 5177
                  Kirk,
                  I am not sure if they are considered correct for judging but I bet they are. No way I would change mine as I believe them to be correct. My 67 is early serial# 15xx built September 66 FWIW.
                  • Kirk M.
                    • June 30, 2006
                    • 1036
                    Kirk,
                    Mine is a bit later, 16,XXX built in April of 67. I really can't tell or know if they are original.
                    • Kenneth B.
                      • August 31, 1984
                      • 2084
                      I agree! I would think any period screw should be OK unless you beleave GM shut down the line if they ran out of the (CORRECT SCREW) & knew that NCRS beleaves Corvettes all had the same screws.
                      PS It's a screw if its screwed in a threaded hole. It's a bolt if it's inserted through holes & a nut is used. Old hardware man set me straight.
                      KEN
