C-3 Console - NCRS Discussion Boards
C-3 Console
  • Glenn B.
    • June 4, 2008
    • 76
    C-3 Console
    Can any one tell me how to remove the fresh air vent knows (w/o ac) so that I may remove the console plate.
  • Thomas H.
    • August 31, 2005
    • 1068
    Re: C-3 Console
    Glenn,
    Push the levers fully forward (closed) and you will see a tiny allen head screw (set screw) recessed towards the bottom of the knob. Loosen the screw with an allen wrench (1/16"??) and pull the knobs off. I just had mine off this weekend, simple once you find the screw!
    Good Luck,
    Tom
    2007 Z06, Lemans Blue
      • 43286
      Re: C-3 Console
      Glenn-----
      There is an allen head set screw near the bottom of the ball shaped knob which faces toward the driver. As I recall, it's a 5/64" size allen wrench. Just loosen the screw several turns and pull the knob off the lever.
      • Harmon C.
        • August 31, 1994
        • 3228
        Re: C-3 Console
        I thought the screw faced to the rear. If the threads are striped they can be hard to remove. I have retaped them to use a larger set screw.
        Lyle
          • 43286
          Re: C-3 Console
          Lyle-----
          It depends what you mean by "to the rear". The screw faces the driver but also could be said to face the rear of the car. However, if by "to the rear" you mean the rear of the knob (i.e. the side which does not have the embossed printing on it), that's not the side the screw is on.
          • Glenn B.
            • June 4, 2008
            • 76
            Re: C-3 Console
            Thanks for all the help guys!
            Glenn
            • Carl H.
              • August 31, 2002
              • 41
              Re: C-3 Console
              Glenn, glad to see you using the forum. Care package will go in the mail Monday or so.
              • Glenn B.
                • June 4, 2008
                • 76
                Re: C-3 Console
                Carl, got the rear vents working!
