Looking for specifics on how I can rebuild an oil pump to reduce oil pressure to pass PV. I have already replaced the pump with a standard Melling M-55, so just replacing the relief spring probably won't help. The engine must have been rebuilt with tight tolerances. I run about 45 PSI at warm idle and jumps to 60 upon acceleration. I have already put nearly 2,000 miles on the motor since the rebuild, so it is already broken in. I have also double checked the gauge with two different test gauges, and the high reading is accurate.
Thanks!
Thanks!
