I just tried to install a new set of brake calipers on the back of my 70. The drivers side fits fine. The passenger side does not have enough room between the caliper and outside of the rotor to install a brake pad. I measured the gap between the inner pad metal backing and caliper and the clearance at the front was 0.152" and rear .132".
I have read an online article with the following advice:
"If a rear caliper is off-center or angled to the outside or a front caliper of is off-center or angled to the inside, simply remove it and add flat washers between the caliper and caliper mounting bracket such that the problem is eliminated. Special washers, in .015-, .020-. .025 and .030-inch thicknesses, are made by Global West to solve caliper position problems.
If off-center or angling of a rear or front caliper is opposite
