68 C3 firewall grommets - NCRS Discussion Boards
  • Michael M.
    • February 15, 2007
    • 455
    Soon, I plan on replacing my engine compartment wiring harnesses as well as all of the vacuum hoses on my 68 427/390hp (L36). I have a manual transmission and no A/C.
    It seems like a good time to replace the firewall grommets. I have looked at the AIM but it is not clear to me what goes through the grommets and how many holes each grommet should have.
    I figure vacuum hoses, tach and speedo cables, oil pressure gauge line, and back up light switch wire must go through the firewall. My engine compartment harnesses are such a mess, and the firewall grommets are missing.
    Can anyone help me out? Thanks.
  • Kevin G.
    • February 1, 2005
    • 1077
    Re: 68 C3 firewall grommets
    One more to add would be the hood release cable grommet.
    Kevin
    • Nick M.
      • September 30, 2005
      • 143
      Kevin
      I see that you own a 72 Coupe. I recently purchased a 72 Convertible LT-1 and was wondering if you can reccomend a good source for parts for the C3s based upon your experience to date.
      • Kevin G.
        • February 1, 2005
        • 1077
        Originally posted by Nick Minoia (44662)
        Kevin
        Nick, Nice car! I've had some local NCRS members show me the ropes. I owe a lot to Tim Raisner, he took me under his wing and without his help I would not be driving the car today. Tim put on a seminar for our chapter, rebuilding trailing arms,(using my T/A's) knowing mine needed to be rebuilt. Just one story! Amazing what he can do with these cars, even over the phone! As far as suppliers, I used Paragon faithfully, with great success and awesome tech. support. Any part that could be rebuilt/refurbished were kept and reused. My intention with 72 was to drive it, and that's exactly what I'm doing, everyday! Good luck, I love pictures hint, hint.
        Kevin
        • Michael M.
          • February 15, 2007
          • 455
          Can anyone help here? Thanks.
          • James B.
            • March 1, 1985
            • 217
            Michael,
            You might want to give www.docrebuild.com a look. Page 20 of their online catalog displays their grommet selection. If you still have questions, you may want to give them a call on their (information only) line.
            -James
            • Larry S.
              • February 1, 1997
              • 24
              Michael
              My 68 390 4 speed w/ PB & PS has a grommet for wiring that I can't see w/out some disassembly, a grommet w/ 3 vacuum hoses passing thru, and a couple of others for misc uses. I can get more specific if I pull some parts and I will if you need that. All of my grommet locations and uses were illustrated in my assy manual. Larry
              • Michael M.
                • February 15, 2007
                • 455
                James, thanks for the suggestion. I did previously look at the docrebuild catalog, but I can give them a call.
                • Terry B.
                  • August 31, 1999
                  • 607
                  Michael,
                  I have a '68 L-36 Automatic that was frame off restored in '06 and Top Flight '07. Here are some pictures of the grommets I believe you are looking for. Let me know if you need more. The mistake I made during the restoration was not taking enough pictures. I took these pictures with everything installed so they may be difficult to see. I hope this helps!
                  Terry Buchanan
                  Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                  Corvettes Owned:
                  1977 Coupe
                  1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                  2003 Electron Blue Coupe
                  2019 Torch Red Grand Sport Coupe
                  • Michael M.
                    • February 15, 2007
                    • 455
                    Thanks to all. With the pictures and the explanation, at least now I know what I am going after. I believe I can figure the rest out. Larry, thanks for confirming a 3 hole grommet for the vacuum hoses. Terry, thanks for the pictures.
