A question, An observation and a ranting - NCRS Discussion Boards
+ More Options
Posts
  • Chuck R.
    • April 30, 1999
    • 1434
    Yup, a three fer deal today
    First the question,
    I purchased a late 68 donor body and noticed that where the driver's side fire wall meets the floor board, there about eight bolts protruding equally between the firewall and the floor board holding a piece of steel plate in place. I've noticed that on my old body and on a couple of "other" bodys I've come across, that juncture seemed to always come apart.
    Was this a factory mod or did Bubba get his hands on my donor body? The heads of these bolts are ground flat just like a rivet.
    The observation,
    This donor car has the bracketing and tabs for the fire wall insulation. I'm opting to re-install these components if they actually help or would it just be throwing good money after bad?
    Any feedback on this?
    Now the rant,
    I cannot believe what body supplies are going for these days! I just can't wait to start paint purchase process!
    Guess I'll have to go into the full conservation mode and stop buying beer and Jerky and go back to Boones Farm and fried Spam
    Chuck
  • Jean C.
    • June 30, 2003
    • 688
    Re: A question, An observation and a ranting
    Nuttin' better than chicken fried spam.
    • Dave F.
      • December 1, 2003
      • 508
      Chuck,
      Are you talking about the area directly below the steering column penetration through the firewall? I'm not seeing anything that answers your description on mine FWIW, though we know how busy Bubba has been over the years (and I don't think he's been eating Spam).
      Dave
      • Henry S.
        • April 30, 2005
        • 816
        Lathered in water gravy, Mmmmm!
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: I don't know there Daver
          Chicken fried Spam Charlie?.......mmm MMM! Now that sounds tasty......
          Maybe it's because I haven't had lunch yet
          The bolts and plate mentioned Dave are dead center of the bend where the flat portion of the floor board makes the first turn upward to make up with the firewall.
          I'm just wondering if this was one of those running changes they made prior to the 69's coming out.
          Kind of along the lines of the additional frame bracing they installed.
          Chuck
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: STOP!!
            You guys are killing me!!!
            One greasy gram at a time that is
            • Harmon C.
              • August 31, 1994
              • 3228
              Chuck
              I think that is a weak point as I have seen repairs in that area on later C-3's. Bubba may have put the pedal to the fiberglass to get a few more horses and cracked the seam street racing.
              Lyle
              Lyle
              • Dave F.
                • December 1, 2003
                • 508
                I don't have anything like that at the angled rise from the footwell Chuck - sorry.
                • Chuck R.
                  • April 30, 1999
                  • 1434
                  Re: That's what I surmised as well
                  As this work was performed prior to the accident it was involved in, I guessed it was either severe body flexing or foot pressure along with material fatigue.
                  It was suggested that as I'll be repairing this area anyway, that I should build it up to prvent this type of issue from re-occuring.
                  It sounds like "sound" logic
                  Thanks for the responses,
                  Chuck
                  • Chuck R.
                    • April 30, 1999
                    • 1434
                    I actually had a few minutes to clean the interior floor area and now it's obvious that this was an attempt to repair and reinforce the floor boards.
                    This should prove fun to correct
                    Good to see you back on the board Daver,
                    Chuck
                    • Dave F.
                      • December 1, 2003
                      • 508
                      Chuck
                      Thanks Chuck. It's good to be back - the last few years have been challenging but as I look back it served me well to strengthen my resolve to complete my project "Fog"
                      As Lyle said, the footwells on our early C3's are weak, downright flimsey to the point of almost negligence IMO. A layer or two of fiber matting applied on the inside ought to give you a bit more rigidity w/o affecting your new padding and carpet. A little creative glass work on the outside should get you back to a decent look.....what else can you do with what you have at this point - go back in time and pluck a new off the line? A little art - a little science, eh?
                      • Chuck R.
                        • April 30, 1999
                        • 1434
                        I'm actually going to look over my old body that has a good fire wall and see just how much work it might take to surgically remove the bad section and graft the good section in.
                        The steel reinforments around the penetration where the wiring harness blocks mate together on the donor body was badly twisted due to the accident it was in and this "swap" would solve that issue as well.
                        More fiberglass work than I had planned on doing, but the end result should produce a superior repair ...........if it's easy to separate.
                        I do hate to carve up that perfectly good firewall though.....
