Starter Identification - NCRS Discussion Boards
  • Robert K.
    • June 30, 2001
    • 212
    Could someone help me identify the starter/application
    with the following #.
    1108368
    Delco Remy
    If from a Corvette, would this starter "work" with a Jan. '67 L71?
    • 43279
    Re: Starter Identification
    1108368
    Delco Remy
    Robert-----
    If you have a 1969 Chevrolet light truck with 307 V-8 engine and 3 speed manual transmission or if you have a 1969 GMC light truck with 250 cid 6 cylinder engine or 307 V-8 with 3 speed manual transmission, you have the correct starter for it. Of course, all that may remain of the original starter is the frame (the part with the numbers stamped on it).
    As far as the numbers being "correct" for a 1967 Corvette with L-71, forget it. As far as the starter being FUNCTIONALLY correct for a 1967 L-71, that's another matter. It depends on its current configuration.
    • Robert K.
      • June 30, 2001
      • 212
      Joe,
      As always - thank you for the information. Looks like someone changed it out in the "early" years!!
      Take care,
      Bob
        • 43279
        Joe,
        Take care,
        Bob
        Bob-----
        What's the date code on this starter?
        • Robert K.
          • June 30, 2001
          • 212
          Joe,
          I did not see one (crawling under the car).....Could you please tell me where the code is located on the starter (in relation to the number I mentioned above)? I'll look for it this weekend as my car is in another garage.....
          Thanks Joe and take care,
          Bob
            Date code should be stamped in the viscinity of the Delco Remy part number.
            Also, understand what others are saying... If a starter was replaced and the replacement starter came from a commercial rebuilder, the numbers on the case are essentially meaningless. Most rebuilders practice reverse assy line techniques, running batches of builds and they don't care about factory originality. So, raw starter cases are re-used to produce this/that rebuilt starter regardless of what Delco Remy PN happens to be stamped on the donor case that was pulled at random from their inventory...
              • 43279
              Joe,
              Bob
              Bob-----
              In the location that Jack mentions and it will be in the format of a single digit, followed by an alpha-character (letter), followed by 1 or 2 digits.
              • Robert K.
                • June 30, 2001
                • 212
                Thank you for the information gentleman - I will look this weekend and reply.
                Take care,
                Bob
