Engine Start Up - NCRS Discussion Boards
Engine Start Up
  • Gary P.
    • May 31, 2005
    • 104
    Engine Start Up
    I just had my 327 rebuilt and was told to use a start up oil. I was told It's different from regular oil. I need a little help as to what oil to use. solid lifter motor
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Engine Start Up
    Gary most would recommend using E.O.S. Assembly Lubricant #1052367. This is a GM product available from any GM car dealers parts department. Comes in a 16 oz container. Your new camshaft and lifters need this for break in. Also there are a lot of postings on this site about using diesel oil instead of regular oil because of the better engine protection for engines with flat tappet valve trains.
    • Christopher R.
      • March 31, 1975
      • 1599
      Re: Engine Start Up
      My engine rebuilder insists on using a single weight oil for first start - 30 weight. He's hard over on no multi-weights. I'm not sure I agree with him, but my engine will be started in an ambient temperature that takes 30 weight anyway, so that's what I'm using. (No, I don't believe in those old foolish wives' tales. But that's not to say they aren't true.)
      One thing that is important is the EOS or something similar. Some of the camshaft manufacturers have their own.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17971
        Re: Engine Start Up
        Caution if your 327 has solid lifters. Diesel oil or oil with ZDDP compound is required. Check the archives and Duke's article in the latest Restorer. Know of several members that lost cams in new engines before the lack of ZDDP became known. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
          • 43290
          Re: Engine Start Up
          Jim-----
          The new part number for EOS is GM #88862586.
            • 43290
            Re: Engine Start Up
            Gary----
            The addition of a pint of EOS to any oil will provide all the necessary protection---and then some.
              • 15706
              Re: Engine Start Up
              There's no such thing as "start-up oil." Use 15W-40 CJ-4 with a bottle of EOS and use a "preoiler" while rotating the engine through a couple or revolutions.
              I've discussed engine breakin many times including my recommendations for filter and oil changes during the breakin period including within the past week or two.
              • Tim S.
                • May 31, 1990
                • 715
                Re: Engine Start Up
                Gary,
                Comp Cams has an additive p.n. COC159. This additive is specifically to address the problems with recent changes in motor oil. Comp recommends this for start up and for continued use to protect the cam. I have also seen a product made by Brad Penn. They have a specific oil for break in. One of our local engine builders swears by it. Hope this helps.
                Tim
