1970 rear sping cup installation - NCRS Discussion Boards
  • Rich D.
    • March 1, 1995
    • 32
    Hi, guys. Does anybody have a good method for attaching the bushing cups into a replacement rear leaf sping, or should I just let the sping tension hold them in place as before?
    I plan to drive the car frequently, if that matters. Thanks.
    Re: 1970 rear sping cup installation
    The typical approach is to crimp the cups using a press...
    • Gary B.
      • February 1, 1997
      • 7020
      Rear sping cup installation; I have a system
      Rich,
      I just finished developing a simple system to do exactly what you're asking about. I'm working on an article for the Restorer on the tooling and how it works with a colleague who just used it this week to redo the spring and T-arm cups on his '65. Send me an e-mail to garybeaupre@comcast.net and I can tell you more about it.
      Gary
      • Gary B.
        • February 1, 1997
        • 7020
        With the spring in the car or out?
        Rich,
        If your spring is out of the car, the task is straightforward, as Jack implied.
        The new system I have will work with the spring in the car, although, of course, you need to remove the main leaf end bolt to use the in-car system.
        Gary
        • Gary R.
          • April 1, 1989
          • 1798
          Those are the same cups used in the T/A. They can be installed off the car by using a piece of steel the diameter of the cup to support it then a couple of ball peen hammers with various size balls is all you need.
          • Rich D.
            • March 1, 1995
            • 32
            Since my spring is off the car and apart for cleaning/painting, this sounds like the best plan. I don't have a press, so is there anything in particular I should tell my machinist when I bring him the bottom leaf and the cups, or is the job straightforward?
            Thanks.
