'68 Rally Wheel Trim Ring - NCRS Discussion Boards
    • 43287
    #31
    Re: '68 Rally Wheel Trim Ring
    Originally posted by Bill Mashinter (1350)
    Here's a picture of a trim ring with the step in the face.
    Bill-----
    That configuration I have NOT seen on a GM trim ring for 68-82 Corvettes. Does this trim ring have the "4 clip" attachment or the "multi-clip"?
    • Bill M.
      • April 1, 1977
      • 1386
      #32
      Bill-----
      Sorry guys. I just clarified that this is not a Corvette trim ring.
        • 15638
        #33
        The picture I posted is one of the original trim rings from my 1970. I'm not sure how that relates to the OEM 1968 trim rings.
        • Ken B.
          • May 31, 2006
          • 233
          #34
          Originally posted by Jim Trekell (22375)
          How many C3's have true original rings? Both of my original owner 68 and 70 C3's had their rings and center caps stolen at different times before 1975. My 70's did not last 4 months.
          I still have the original rings for my 75.As a matter of fact i am going to post them on ebay
          • Dave F.
            • December 1, 2003
            • 508
            #35
            Both sets I have (corroded ones on the car when I bought it) plus the service replacements I bought from Joseph Chevrolet in 2003 look exactly like yours.
            • Harmon C.
              • August 31, 1994
              • 3228
              #36
              I just looked at about fifty trim rings getting ready for Carlisle. I found that all trim rings I had with one set of clips on the valve stem the one inch front face that gets curbed was flat. If the clips were not on the valve stem the one inch face has a slight concave arc to it. What is the going price to get a few light scratches out of a set of trim rings?
              Lyle
              • Ken B.
                • May 31, 2006
                • 233
                #37
                Originally posted by Dave Fleeman (41052)
                I guess it depends on the year - what year is yours, Ken?
                My '68-'69 TIM&JG only addresses four clips with one always mounted at the valve stem. There is no other mention of whether the ring is smooth or has a step; nor does it address anything about the valve stem opening or inner lip finish of the trim ring.
                Mine is a 75..They have 4 clips just as they should
                • Terry B.
                  • August 31, 1999
                  • 607
                  #38
                  I have attached a picture of the trim rings on my '68. It does have the step in the outer portion of the ring. It has the 4 clips and in the correct position. By the correct position I am referring to the numbers on a clock. If the vave stem hole is 12 position, there is a clip there and at position 3, 6, and 9. I am not the original owner of the car but did not lose a point on the trim rings in the 6 times it has been judged. Top Flight 2007 was the latest judging of the car.
                  Terry Buchanan
                  Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                  Corvettes Owned:
                  1977 Coupe
                  1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                  2003 Electron Blue Coupe
                  2019 Torch Red Grand Sport Coupe
                    • 43287
                    #39
                    Ken-----
                    All of the GM 68-82 wheel trim rings have the 4 clips for attachment to the wheel. That's for sure. The issue of the POSITION of the clips is a separate one. Some say that the rings used in PRODUCTION had the clips in a particular position with one at the valve stem hole and the others spaced 90 degrees apart. It has also been inferred that it was the SERVICE-only trim rings that had the clips randomly positioned, but still 90 degrees apart.
                    I have a hard time understanding how GM would have had certain trim rings with a "precise" location of clips manufactured for PRODUCTION while having other trim rings OF THE SAME PART NUMBER manufactured for SERVICE with more random positioning of the clips.
                    I tend to think that the exact same rings were used for PRODUCTION and sold for SERVICE at any particular time. It may be that at some POINT IN TIME the requirement for "precise" positioning of the clips was eliminated. This may have occurred before or after the rings ceased to be used in PRODUCTION.
                    • Harmon C.
                      • August 31, 1994
                      • 3228
                      #40
                      I agree Joe at some point all trim rings were made with the one set of clips placed at random. I have some of what I call the later style that you can still buy and sometimes a set of clips is very close to the valve stem hole. I know on 75's the clip was still on the valve stem as stated in the 75-77 manual.The manuals I have for 78-82 just say four clips.
                      Lyle
