My 65 350HP air cleaner crankcase vent chrome tube which exits the bottom side of the air cleaner's base is now loose to the point it will fall out when I remove the base. Was this tube pressed, soldered or what originally?? Should I try soldering/spot welding once I determine the correct position? Any suggestions?
Thanks!
Dick Gutman
Thanks!
Dick Gutman
