Hi All;
I've just got my 1965 BB back from the machine shop after a rebuild... The motor has about 150 miles on it since break-in on their bench. As I am driving it I am naturally keeping an eye on everything including oil pressure.. The car has the correct 80# gauge in it.. Driving around I will see about 40# + or - which I suspect is fine. My concern is at idle... where I am seeing only about 20# via the gauge. Is this normal?
I will zip through the shop manuals to see if they say anything about this but was wondering if you guys had any thoughts....
Thanks!
Joel
Duke, I know you will probably read this... How long should I keep the break-in oil in the car before I replace it with CJ-4??
Thanks!
Joel
 BB Oil Pressure
									BB Oil Pressure
