Re: Distributor Vacuum Advance Part #
Bidding will begin at $1000. (just kidding
). Its value is whatever a B-code NAPA goes for UNTIL / IF the '65 TIM&JG recognizes it for the '076' distribs.
Got this off eBay about 5 years ago. Seller correctly identified it as a '238' in spite of the box # 1116168. In fact, after following this discussion, I'm wondering if the owner was having the problems discussed above, and elected to change to a '168'. This can looks almost new, but there are screw marks of it having been installed at one time. Also, the little rubber sleeve is hurting.
). Its value is whatever a B-code NAPA goes for UNTIL / IF the '65 TIM&JG recognizes it for the '076' distribs.Got this off eBay about 5 years ago. Seller correctly identified it as a '238' in spite of the box # 1116168. In fact, after following this discussion, I'm wondering if the owner was having the problems discussed above, and elected to change to a '168'. This can looks almost new, but there are screw marks of it having been installed at one time. Also, the little rubber sleeve is hurting.
