1978 dash lights out - NCRS Discussion Boards
  • Larry N.
    Infrequent User
    • August 31, 2002
    • 10
    no dash or guage lights work, parking lights and headlights work, tach works, when I turn the dimmer the courtesy and dome light works. Is it still possible for the switch to be bad?
    Re: 1978 dash lights out
    That's a classic 'warning' symptom of Chevy that the car's tail lights aren't working....
    • Larry N.
      Infrequent User
      • August 31, 2002
      • 10
      Jack
      thanks for the info, they do work, any other ideas?
      • Martin N.
        • July 30, 2007
        • 594
        Larry-
        I'm not that sure about a 78 but did you look at the fuses? Perhaps there's an issue there. If not maybe a ground or the headlamp switch.
        Marty
        • Larry N.
          Infrequent User
          • August 31, 2002
          • 10
          fuse is good, do you know where the ground would be?
          • Martin N.
            • July 30, 2007
            • 594
            LARRY-
            Not sure on a 78. Do you have a GM service manual, it'll be in there. The last time I had my 74 dash apart (about 7 years ago) I believe each bulb is a single (hot) wire socket.
            Marty
            • Larry N.
              Infrequent User
              • August 31, 2002
              • 10
              marty
              78 has a printed curcuit board for all lights, but thanks
