427 -425 spark plug wires - 1966 - NCRS Discussion Boards
  • Larry S.
    • September 19, 2007
    • 204
    I checked the archives, but couldnt find what I was looking for. When putting the plug wires into the distributor cap (looking down on the cap from the front of the car) in which position should the #1 wire be installed? Should it be on the left or right side of the access door?
    Thanks in advance. I know that the firing sequence is the same as on the small block.
  • Douglas L.
    • August 31, 2003
    • 302
    Re: 427 -425 spark plug wires - 1966
    1 to the left of the access door
    • William C.
      • May 31, 1975
      • 6037
      See Sheet B3 in the L72 section of the assembly manual.
      Bill Clupper #618
