67 Rocker Panels-Undercar Exhaust - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Anyone have any tips on repainting the black on my 67 rocker panels. They have never been repainted before.
    Recommended brand, type of paint?
    Jerry Fuccillo
  • Douglas L.
    • August 31, 2003
    • 299
    Re: 67 Rocker Panels-Undercar Exhaust
    Jerry,
    I refinished a set over the weekend using KRYLON semi-gloss Black. They came out just fine.
    • Lorne G.
      • June 30, 1988
      • 118
      Ditto for me. I used the same paint and mine also turned out great.
      Lorne
      • Gerard F.
        • June 30, 2004
        • 3806
        Douglas/Lorne,
        Did you strip them, or use any primer.
        What was the prep?
        Jerry Fuccillo
        • Howard W.
          • December 1, 1998
          • 121
          I have also painted with Krylon 1613 semi flat black, I also primed them first with Krylon grey sandable primer. comes out real nice
          • Lorne G.
            • June 30, 1988
            • 118
            I took a slightly different route but still got excellent results. I stripped off the old black paint with a standard paint stripper, washed the area thoroughly and used a red oxide primer. I lighly sanded the primer with a 400 grit and then a 600 grit sandpaper then applied the black finish.
            Lorne
