Headlight motor speed - NCRS Discussion Boards
  • Rex T.
    • December 1, 1984
    • 455
    Is there any way to adjust the speed of 67 headlight motors so both open at the same time? I took both apart and lubed the gears. After reinstalling them, one motor is about 3 times as fast as the other.
    Rex
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: Headlight motor speed
    The speed is not adjustable. However, you may have set/adjusted the gear clearance such that one runs faster than the other. Also binding in the bearings etc will cause a speed difference.
    There also could be debris on the brush commutator.
    Test them on the bench before installation
