Can someone identify and give its purpose? - NCRS Discussion Boards
  • David D.
    • January 1, 2005
    • 416
    While I had my early '64 inner passenger door panel off, I noticed what looked to be some sort of adjustable screw/nut assembly, but I couldn't figure out what it was possibly used for. Any help would be appreciated.
    Thanks in Advance,
    David
  • Dan H.
    • July 31, 1977
    • 1372
    Re: Can someone identify and give its purpose?
    David, that is used to adjust the front window track in or out for smooth operation. Same nut as the rear valence end fastener I think, check out assembly manual for part numbers etc.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Bill W.
      • March 1, 1980
      • 2000
      this is to tilt your window channel in or out . Bill
      • David D.
        • January 1, 2005
        • 416
        Thanks guys....makes sense now. I gather I'm not going to mess with it unless there are some problems with window tracking or sticking while down......
        David
        • Alan D.
          • January 1, 2005
          • 2053
          David, check your rear valance panel for the two screws and nuts which hold the lower end of panel, one on each side. Look at AIM, pg D68 #9, if confused by my description. That is the same nut you are questioning so if missing from back panel, here it is.
          • David D.
            • January 1, 2005
            • 416
            Alan,
            If I'm correct those two screws are located on the end of the door?
            David
