C3 Rivets and Insulation Fasteners - NCRS Discussion Boards
  • Tommy F.
    • August 13, 2007
    • 97
    Today I had a couple of things to do on my '75 that I have been dreading, but they actually went very well, and I wanted to share the what and the how:
    I had 2 "wire holders" on the firewall that needed to be re-riveted, and I have heard horror stories on using the correct aluminum rivets....
    I took an air chisel tip, cut it off square, and drilled a "dimple" (3/16 bit, approx 1/8" deep) in the end. I had a buddy "buck" the inside with a mall head. 30 seconds later, both were done, with a perfect dome, and very tight. I imagine you could play with the rivet length to change results depending on what you were joining, but the 5/8" rivets from CC worked perfectly on these straps.
    Next, I had to install 3 of the rubber plugs in the firewall (the ones that hold the insulation). Again, I have read how difficult this was, and even with the "proper" tool, holes got poked in the plugs...
    I soaked the plugs in warm water, shot some WD 40 on the tips, and used a 3/16 drift punch to push them in. I swear that they went in so easily, I thought that I broke them....(the punch made the difference, because on the last one, I grabbed a similar tapered punch by accident, and it would absolutely not go in).
    It's a happy day in "Monster Garage" !
    • 3418
    Re: C3 Rivets and Insulation Fasteners
    Tommy,
    You proved again that 'nothing beats a day playing with an old car'. Since both jobs went so well you probably had time to try to do something else.
    • Richard F.
      • May 31, 1986
      • 193
      My policy is that if a planned job goes well to completion, I find other jobs to do until I manage to ruin something or injure myself.
