C1 Dash Plate - NCRS Discussion Boards
C1 Dash Plate
  • Richard H.
    • February 28, 1985
    • 241
    C1 Dash Plate
    Any suggestions for a compound to attach the upper and lower trim strips to the dash plate and to attach the dash plate to the bracket/padding on the dash? Thanks.
  • Richard T.
    • January 31, 1979
    • 858
    Re: C1 Dash Plate
    The dash plate (aluminum) attaches to a steel frame that has studs protruding from the back side. These studs pass through the holes in the fiberglass portion of the dashboard and are retained with nuts and washers.
    The factory assembly spot welds the stainless upper and lower trim strips to the frame. To restore the spot welds are ground off, add the new insert with the stainless trim and epoxy in place.
    • Richard H.
      • February 28, 1985
      • 241
      Re: C1 Dash Plate
      Since the trim is not attached to the plate, it seems to me you are suggesting epoxy to attach the trim to the insert and then epoxy the whole unit to the frame. Or, are you suggesting attaching the trim to the plate with epoxy and slide the trim in. Thanks.
      • Dennis A.
        • April 30, 1999
        • 1010
        Re: C1 Dash Plate
        Position the plate, then slide the trim over very carefully. epoxy is only needed at the weld spots..... hold it with rubber bands over night.
        • Richard T.
          • January 31, 1979
          • 858
          Re: C1 Dash Plate
          Richard,
          The stainless trim holds the insert and frame together, apply the epoxy in the rear at three or four locations. Once the assembly is installed it cannot be seen. Rich
