1966 turn signal flasher bracket - NCRS Discussion Boards
  • Curt C.
    • May 31, 2000
    • 49
    Ever since I have owned my 1966 roadster, the turn signal flasher has just been "stuffed" in with other under dash wires. I recently bought a flasher bracket and can't tell where it mounts. It has a black phosphate screw but I can't determine what is appropriate. Any help would be greatly appreciated, a picture even more so!
  • Donald T.
    • September 30, 2002
    • 1319
    Re: 1966 turn signal flasher bracket
    The bracket may not be too clear in the pic, but it mounts on the radio side panel behind the electric antenna switch.
    • Randy S.
      • January 1, 2003
      • 586
      Chris,
      The flasher bracket mounts to the drivers side radio panel along the top edge. It will be forward of the antenna switch. Should be a hole there already.
      Randy
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Randy Swartout (39156)
        Chris,
        Randy
        Curt -- here's another pic of the screw and bracket / clip (to upper left of P.Antenna switch) that Randy mentions
