I am working on restoring an original 2818, and some of the hardware finishes have me a bit confused. This carb was removed long ago and had never even been apart. It appears that all of the base plate hardware was either painted black or zinc plated (no dichromate), as can be seen in the first pic. Also, the choke rod appears to have been painted black as well. The fittings appear to be zinc plate. None of these parts show evidence of dichromate finish. I have had a couple of 2818s restored by Holley over the years, and these parts come back with the dichromate finishes. Also, other restored 2818s I have seen have had dichromate finishes as well. Any thoughts on the correct finishes for these parts?
Holley 2818 Carb Finishes
Re: Holley 2818 Carb Finishes
The accelerator pump link is black phosphate.
The float adjuster jam nuts are clear zinc.
Everything else is zinc dichromate, including the fuel elbow, vacuum orifice elbow, secondary throttle shaft link, and choke link.
If you want pix, let me know, and I'll shoot some.
JoeLast edited by Joe C.; July 19, 2008, 11:35 AM.- Top
..... It appears that all of the base plate hardware was either painted black or zinc plated (no dichromate), as can be seen in the first pic. Also, the choke rod appears to have been painted black as well. The fittings appear to be zinc plate. None of these parts show evidence of dichromate finish. Any thoughts on the correct finishes for these parts?
Can provide pics if needed.- Top
Thanks Wayne. I agree that black phosphate is more likely than paint. It does appear semi gloss when rubbed, just as you describe. The one I have is a 531 date code, and came off a late 65 vette. It does appear all original.- Top
- Top
