AC Plug questions - NCRS Discussion Boards
AC Plug questions
  • Randy S.
    • January 1, 2003
    • 586
    AC Plug questions
    Thinking about putting plugs and wires on the 66 300HP. The AC R45's and wires are of unknown age and I have a small miss that feeks like ignition.
    Are the AC R45 still available? No luck yet. Or should I be considering the 45S which is extended tip? What is the applicatiuon for extended tip?
    Randy
    • 43249
    Re: AC Plug questions
    Randy
    Randy----
    The AC R45 spark plugs are still available; no problem, at all. In most cases, I would use the R45S in place of R45, though (assuming, of course, that I was using AC spark plugs, at all, which I wouldn't be).
    • James R.
      • September 30, 2005
      • 93
      I use R45's in my 65, 327/365hp. Bought them though my local Chevy dealer. Runs great.
      • Jim D.
        • December 15, 2006
        • 39
        Randy----
        What kind of plugs do you use Joe ?
          • 43249
          Jeff----
          I use Champions ONLY. Many years ago I tried all the available brands. I found Champions to run the best. AC spark plugs are actually a "prettier", more refined-appearing spark plug. By contrast, Champions are almost crude-appearing. However, the Champions ran better than AC or any other brand I tried (of course, there are more brands out there now). In a spark plug, performance is far more important than appearance.
          The Champion equivalent of the R45 is RJ8C and the R45S is RJ18YC.
          • Jim D.
            • December 15, 2006
            • 39
            Thanks Joe, appreciate your knowledge and expertise.
            • David D.
              • January 1, 2005
              • 416
              Joe, what would be the recommendation for a 327 x 365hp 'Radio Delete'? Obviously I don't need the R.
              Is there such an animal?
                • 15706
                Delco has discontinued most of the non-resistor plugs, but NGK and Denso make non-resistor equivalents to the old AC 45 - the B4 and W-14U, respectively.
                BTW, Denso plugs have been OE in all Corvette engine since the beginning of the C5 era.
                • David D.
                  • January 1, 2005
                  • 416
                  Duke,
                  Thanks....I appreciate your sharing.
                  David
                    • 43249
                    David-----
                    I would use the Champion RJ8C. This is a resistor plug, but I wouldn't be concerned about that, at all.
