Wire gauge for 1960 ammeter circuit? - NCRS Discussion Boards
  • David T.
    • August 31, 1995
    • 51
    This has probably been beat to death, but a search did not give me a definitive answer about wire size.
    I want to add a fusible link to my '60. Most info I found on the forum says my ammeter feed (black wire at the starter) is a 10 gauge and should be protected by a 14 gauge fusible link. My wiring diagrams, however say that the wire in question is a 12 gauge which would call for a smaller 16 gauge link.
    So here are the questions. Is the ammeter feed a 12 or is it indeed a 10 gauge? Are the factory wiring diagrams in error?
    Should a fusible link be used elsewhere for additional protection? (Horn relay or voltage regulator for instance.)
    By the way of further information. My main and engine wiring harnesses are NOS GM. These are the C1 replacement harnesses which were offered in the 1980's
    Thanks in advance for any information.
    Dave T.
  • William C.
    • May 31, 1975
    • 6037
    Re: Wire gauge for 1960 ammeter circuit?
    Wiring print calls for a 12 ga on the #1 (black) wire at the ammeter, the 2A/B (red) double at the ammeter has one 12 ga and one 14 ga crimped on the same terminal.
    Bill Clupper #618
    • David T.
      • August 31, 1995
      • 51
      Thanks, Bill! A 16 gauge fusible link at the starter it is.
      Dave T.
