54 12 volt---use what for a headlight switch? - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5141
    I'm helping with a 54 that has a V8 in it and has the gauges converted to 12 volt. All the bulbs are also changed--but the headlight switch has not been changed, and the headlights flash on and off as if there is an internal circuit breaker. What do you use for a switch? The 56-57 has different terminals--what about a 55?
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 54 12 volt---use what for a headlight switch?
    as i recall, there's a circuit breaker built into the 53 and 54 switches. maybe yer buddy roy b can answer the" will the 55 switch work" question.. regards, mike
    • Roy B.
      • February 1, 1975
      • 7044
      Your harness ends are different , the 54 6V switch should work it's just a on-off switch
      But the rheostat to dim the lights may burn out,and the 6V harness is not made to carry 12V the 55 is the same as 56-57
      • Mike E.
        • February 28, 1975
        • 5141
        I was aware the terminals were different--is there a switch that will readily work? Surely someone has done this interchange before and used a V8 in a 54!
        • Joe R.
          • July 31, 1994
          • 287
          Mike, my 54 was a V8 12 volt for most of it's life (40+ years) and used the 6v headlight switch and dimmer rheostat for all that time with no problems. Remember, 12 volts uses less current than 6 volts; the switch contacts and rheostat winding are under less strain at 12 volts. Also, the 6 volt wiring carries less resistance than 12 volt wiring due to the wire sizes being generally larger, so the 12 volts will work well with the 6 volt wiring.
          Your circuit breaker issue sounds like a dead short to ground somewhere. Maybe the headlamp circuit is mis-wired?
          Joe
          • Chuck W.
            • May 31, 2002
            • 257
            I don't see why the 54 harness would not handle a 12V system. At 12V, given the same Wattage, the current would be half that of an equivalent 6V system. The problem is usually the opposite.... when someone replaces a battery cable in a 6V system, for example, with a 12V cable. The diameter is smaller because the 12V system has a lower current requirement. Thus the new 12V cable will not be able to carry the needed 6V system current requirement. Ohms law!
            • Bruce B.
              • May 31, 1996
              • 2930
              My old V8 54 #0039 used all the 6 volt electrical components except for the bulbs and flasher. Drove it for a year or so with no problems. As stated in an earlier post the wires are of a larger gauge for the 6 volts and handle the 12 volts without any problems.
              Bruce B.
                When I bought my '53, painted it black, converted it to 12 volts, and stuffed a '58 Buick nailhead in it (in '59, when the photo below was taken), I used the existing headlight switch and had no problems.
