1966 frame stencil questions; July build date car - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7082
    I need help from '66 owners!
    I've searched the archives and I can't find the answer to several questions about the frame stencil that I bought from Quanta (in 2003 and I'm just getting around to using it...) for my July build date '66. The Quanta stencil consists of the following two lines of numbers:
    303196-28
    3871317-7-1-66
    If I paint the stencil on with the frame upside down, when the frame gets turned over the 303196-28 number will then be closest to the ground. Both the third edition and the fourth edition of the 1966 TIM&JG say: "The part number 3871317 appears closest to the ground". So, I have several questions. Is the TIM&JG correct or is Quanta correct in terms of which number is closest to the ground when the car & frame are back together right side up? Secondly, did late build date '66s have the date (e.g., 7-1-66) part of the stencil as opposed to marked in grease at I thought was correct for '65 and '66?
    As an aside, the stencil Quanta sent me is actually inconsistent with their Technical Bulletin #7, dated 7/12/89, that came with the stencil since that bulletin shows the 3871317 number closest to the ground when the frame is rightside up. So their 1989 technical bulletin agrees with the '66 TIM&JG, but their stencil doesn't. Does anyone know if Quanta has a revised Technical Bulletin #7 with a revision date newer than 7/12/89?
    Gary
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 1966 frame stencil questions; July build date car
    Gary;
    Let's send you back for another round.
    Stu Fox
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Hi Gary,
      The part #3871317 IS closest to the ground when the frame is right side up.
      The other number should be 3031962 with the last digit being a 0-9.
      Both appear upside down when the frame is righted.
      Just forward of these IS a production pull date in grease pencil right side up.
      HaND
      • Greg T.
        • January 1, 2004
        • 136
        Based on the picture from page 316 of Noland Adams Resto Guide your stencil is wrong. My stencil from Quanta agrees with the Judging guide.
        Mine is
        387.1317
        303.196.21
        Per Tripoli, Corvette Chassis Resto Guide the 21 is an AOS jb # and could be any number
        • Gary B.
          • February 1, 1997
          • 7082
          1966 frame stencil; Quanta research database
          Based on a several known original stencils on '66 cars and some new data that Quanta has acquired in recent years, Quanta made a new stencil for my '66 to replace the stencil I bought from them about 4 years ago. The numbers on the new stencil are:
          3871317-27
          303196-713-66
          This corresponds to a frame pull date of 7/13/66.
          Gary
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1463
            No, Harry, the frame stencil numbers referred to thethe frame only and had no relativity to the equipment, components or details on the rest of the car.
            HaND
