firing order - NCRS Discussion Boards
firing order
  • John F.
    • March 23, 2008
    • 2414
    firing order
    I have taken the dist out w/o marking position of rotor. I installed the breakerless kit from LL and have the dist back in, but not sure if I am close with the rotor to #1. Where is #1 looking down at the dist cap from above? Which side of the window? It appears #1 wire is on the left side of the window when looking at the window, but the rotor is pointing at #2 which is the next plug wire going counterclockwise. HELP!
  • Joel F.
    • April 30, 2004
    • 659
    Re: firing order
    Sorry John,
    I'm not sure what you are asking but here is a picture of the firing order.
    • William C.
      • May 31, 1975
      • 6037
      Re: firing order
      look at your AIM, Section 6 sheet 12 or so (I'm looking at a '60 book) Looking from the top, #1 is to the passenger side of the engine certerline, then looking from above, clockwise it's 1-8-4-3-6-5-7-2
      Bill Clupper #618
        Re: firing order
        Here's a photo showing the correct distributor orientation and wire indexing - it's not a Corvette, but it's the same on all Chevy small-blocks.
        • John F.
          • March 23, 2008
          • 2414
          Re: firing order
          Thank you guys! I really appreciate the help. I hadn't pulled a dist in25 years. "Mad cow".
          John
