What process do I need to do to get them pumping, they worked before just by putting water in jar and hitting button, since paint I just checked and now won't work, can hoses be reversed, vacuum would be the one with suction (on tongue hmm) can hoses at swithch be reversed and tried and what does cable at switch do to pump at firewall? Tried reversing hoses at jar, took unit apart in jar and cleaned, water goes in and out of jar and connections fine, water blows thru hose and works fine at winshield fine manually? Thanks again Brad
