1960 fender reinforcement - NCRS Discussion Boards
  • Michael B.
    • March 31, 2008
    • 88
    Hello, has anyone used the angle stripes that go under the front fenders beneth the top moulding on a 60 vette, and did they strengthen the fenders as claimed,thanks michael
  • William B.
    • April 30, 1975
    • 942
    Re: 1960 fender reinforcement
    Yes, they are well worth the time and investment. I have had my 59 judged at a regional and recieved no point deducts. In you lean or push on the fender of one with and then one without the reinforcement beams, there is a noticeable difference in the strength.
    • Gary B.
      • September 30, 1987
      • 305
      I put them on my `62 and they made a big difference. I put them on with minimum bonding material so the may be removed.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        I thought what Michael was referring to are the steel angle iron items attached with the fender spear hardware - common to 1958 Corvettes to strenghten the front fenders. Am I confused again?
        • Michael B.
          • March 31, 2008
          • 88
          gary do these need to be glassed in I thoght they were held in place by the moulding studs ?? thanks michael
          • Gary B.
            • 305
            My moulding studs were not the best so my friend, who restores Vettes added a bit of bonding material.
            • Joe M.
              • April 30, 1990
              • 1343
              After reading the Q&A's, I can not figure out if you are talking about metal strips or fiberglass strips. Which is it?
              Are they available through the standard vendors?
              Are they an original part?
              • Dennis C.
                • January 1, 1984
                • 2409
                Yes, available through vendors. They are original to your car only if they are designated in your AIM. IIRC, they were a '58 only item. However, not a bad idea on 58/62 since they work and can be easily removed (if one only uses spear mounting studs)... Dennis
                • Roy B.
                  • February 1, 1975
                  • 7044
                  They did strengthen the fenders ,later years added better bonding strips and I think thicker glass.
                  They were a 58 item and wibbited (flat head) on to the under fenders,hidden by the top ss, some body shops added them when doing fender repairs on later Corvettes. But this is my 2 cents only
                  • Michael B.
                    • March 31, 2008
                    • 88
                    joe, they are available from corvette central and also zip in richmond va they are $100.00 as you can see they bolt under fender to moulding studs and seem like a great way to strengthen top of front fenders I am ordering a pair monday thanks everyone for your comments,michael
                    • Dennis C.
                      • January 1, 1984
                      • 2409
                      Hey Roy, Thanks for that additional wibbiting info. My late '58 did not have the reinforcements, so I've never really inspected the method of attachment. Your explanation is appreciated and makes sense. Dennis
