C3 69 L46 lower alt bracket - NCRS Discussion Boards
  • Jimmy B.
    • July 31, 1980
    • 584
    Does anyone have a picture of the lower alt bracket for a 69 350/350?
    Is it cast iron or stamped steel? I can't find mine anywhere and now it appears I need a replacement. Is it the same as the mid 60's sbc with rams horns exhaust manifold (mount on the end of the LH manifold and water pump stud)?
    Thanks in advance.
    Jim Blakely
    • 43285
    Re: C3 69 L46 lower alt bracket
    Thanks in advance.
    Jim Blakely
    Jim----
    The bracket was GM #3846565. It was used on 1965 small blocks with C-60 as well as all 1966-71 small blocks. It is pictured below.
    • Jimmy B.
      • July 31, 1980
      • 584
      Thanks a lot Joe. I still can't figure out where my original bracket could be.
        • 43285
        Jim-----
        That's a problem for which I have no answer.
