Picture of a 1960 oil pan? - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    Can someone either email me or post pictures of a correct 1960 corvette oil pan. I saw several varieties of oil pans at Bloomington. These oil pans had the 3 steps with the center, rear, bottom oil drain plug. Any photos of a known correct 60 oil pan. The pan I want is for the high performance engine.
    Thanks For Your Time.
    DG
  • William C.
    • May 31, 1975
    • 6037
    Re: Picture of a 1960 oil pan?
    If you do a search of the archives there was a fine writeup of oil pans from '57-60 some time back. It referenced an article by Loren Lundberg, but I don't think Loren made the DB submission. 60 was the first year for a trapdoor on the SHP pan, and he has some really good illustrations in it. I think I had to search "oil pan 60" or something similar to find it, but it is very well done.
    Bill Clupper #618
    • Dick G.
      • May 31, 1988
      • 681
      Thanks Bill. Will do.
      DG
      • Mark P.
        • May 13, 2008
        • 934
        On June 25, 2008 I posted some pictures of a pan I was looking at for a 1960 and Loren Lundberg who wrote the oil pan article for Restorer said it would be correct if it had the right 2 1/4 depth for the main seal. The seller on the auction website would not respond to that question after 3 tries so I didn't pursue it.
        • William C.
          • May 31, 1975
          • 6037
          Dick, if you haven't found the post, I found it searching "1960 oil"
          Bill Clupper #618
          • Dick G.
            • May 31, 1988
            • 681
            Bill
            You have a PM.
            DG
