When I tried to put the harmonic balancer pulley back on my '61, I find that one of the bolt holes is stripped, and will not tighten. How can I repair without having to replace the balancer?
Harmonic Balancer Bolts Stripped
Tags: None
Re: Harmonic Balancer Bolts Stripped
Hmmmm, shouldn't all of the threaded holes be heli-coiled for proper "balance"?- Top
Richard-----
I don't think one needs to go that far and, personally, I would not. I believe the effect on balance of the damper would be negligible when installing a heli-coil in one of the pulley bolt holes. You're replacing, essentially, an equal volume of steel with an equal volume of steel. I feel VERY confident that any effect on balance would be well within the normal factory tolerance. These things were not balanced like rotors on a jet engine.In Appreciation of John Hinckley- Top
