C3 Harmonic Damper/Balancer Date Code? - NCRS Discussion Boards
  • Pat M.
    • April 1, 2006
    • 1582
    Hi everyone. This is the balancer off my 350/300hp, build date of May, 70. Are either of these numbers date codes?
    Julian date of 99 69 (April, 69),which would be WAY off for my car?
    K1 69 (Nov., 69), which would be acceptable, and in fact match my original carb date?
    Neither?
    I have asked the previous owners and they simply don't remember if the balancer is original to the car.
    Thanks, Patrick
    • 43281
    Re: C3 Harmonic Damper/Balancer Date Code?
    Neither?
    Thanks, Patrick
    Pat-----
    The "9968" is NOT a date code; it's the last 4 digits of the casting number for the balancer HUB. The other series of characters may very well be a date code; I'm not really sure. In any event, these characters could not be seen with the balancer mounted on the engine.
    • Dick W.
      • 10483
      Pat, I could buy into the K-1 being a date. If you will notice, it looks like the date plate on the blocks. Most cast iron casting dates were plates attached to the sand mold.
      Dick Whittington
      • Pat M.
        • April 1, 2006
        • 1582
        Thanks guys!!
        • Wayne M.
          • March 1, 1980
          • 6414
          Pat-----
          The "9968" is NOT a date code; it's the last 4 digits of the casting number for the balancer HUB. The other series of characters may very well be a date code; I'm not really sure. ..
          Anyone know when they STOPPED stamping the date code on the outer ring, timing cover-side vertical edge of the balancers (or at least the finned hi-horse ones) ? My early '65 has 'H64' (or is it '64H'; got it written down somewhere). This can be seen from below when crank positioned appropriately.
