Having problems with a minor fuel pump leak on my 63. I think I know what the problem is but here goes. Right before the Seven Springs regional we were cleaning up the chassis and noticed the pump was ouzing a lot of fuel around the bottom round magnesium plate that is held on with two screws.
So I took the mag cover or plate off. Sanded it flat on my surface plate. Then I used another new repro rubber one piece gasket. Noticed that the screws were a little long holding the cover on. SO I used another pump for parts and put the correct blackened fillister screws on. Correct length.
Started the car up and no leaks. Was relieved. Well now the thing is damp again. Slight drip or stain on cardboard under the car. Still has an issue. Running 100LL Aviation fuel. Do you suppose this fuel is interacting with the repro rubber gasket? The gasket I removed was repro black rubber and it seemed to be of the wrong material. Didn't feel right? I said to my friend look at this material. Today my friend and I were talking as to why the pump still has a minor leak. Your thoughts please. Thanks, John
P.S. So where can I buy the correct gasket for my 4657 pump.? The bottom round one. Want the real deal.
Shape up, JD
