Fiber Board Storage Tray - NCRS Discussion Boards
  • Jamie F.
    • May 20, 2008
    • 337
    My '69 still has its original fiber board storage tray above the jack. It is not too bad for a 40 year old piece, but is starting to separate at some of the edges. It seems like all the replacements are plastic and I would like to keep the original. Does anyone have a recommendation on how to "restore" or preserve the original?
  • Kevin G.
    • February 1, 2005
    • 1077
    Re: Fiber Board Storage Tray
    Jamie,
    Check your driveline there is someone that reflocks them.
    Kevin
    • Jamie F.
      • May 20, 2008
      • 337
      Thanks Kevin!!!
      • Pat M.
        • April 1, 2006
        • 1582
        Jamie - I've restored several of these trays with what I think are great results. It's not that hard.
        You can wet and reshape warped trays using heavy objects, good ole Elmer's glue does WONDERS for delaminated lips and tears, and DonJer (www.donjer.com) makes a great yet cheap "mini-flocker" kit for the inside.
        Check out the attached pics to see what can be accomplished.
        Good luck
        • Jamie F.
          • May 20, 2008
          • 337
          Wow Pat, great work! You've inspired me! Mine is not as bad as those so I'll give it a shot this weekend!
          Thanks!
          • Jamie F.
            • May 20, 2008
            • 337
            Pat, Did you use the Rayon or Nylon mini-flocker kit?
            • Pat M.
              • April 1, 2006
              • 1582
              I've always used the Rayon kit, although a DonJer rep recently claimed that the Nylon fibers may "lay down" a bit better, and be less subject to slight indentations when touched. I've always simply patted mine down after they're dry to eliminate this problem.
              Feel free to email me if I can be of any help.
              • Martin N.
                • July 30, 2007
                • 594
                PAT-
                Great info. One of my winter projects was to look into refurbishing all 3 of my storage / battery compartments. At least now (thanks to you) I have an alenative method of doing some resto work here at my home shop.
                Marty
                • Jamie F.
                  • May 20, 2008
                  • 337
                  Thanks Pat, just ordered the kit!
                  • Pat M.
                    • April 1, 2006
                    • 1582
                    No problem guys, glad to help. It's a very satisfying project.
                    A couple more tips I should add for the best results:
                    After removing all of the old flocking (I scrape it off or use sandpaper), try to sand the surface reasonably smooth - larger imperfections will show through the flocking.
                    I also like to apply a LIGHT spray of flat or semi-flat paint inside first (of course mask the outside) to darken any light areas which sometimes can show through the flocking, despite the fact that the adhesive is black.
                    Also, use a larger adhesive brush than the one that comes with the kit. The kit's brush is so small it takes forever to apply the glue, while a larger brush applies the glue much faster, leaving the glue wetter, and giving better adhesion of the fibers.
                    Also be forewarned that re-flocking can be messy, and those tiny fibers can get EVERYWHERE, including on you and your clothes! And use a mask!
                    • Reba W.
                      • 938
                      There is a manufacturer's date on the bottom. Don't obliterate it.
                      • Reba W.
                        • 938
                        As someone has reminded me, the date on the box is sometimes missing. I meant to emphasize that if it is there, don't do anything that might remove it. We see more with a date than without.
