Question on timing chain gear alignment - NCRS Discussion Boards
  • Jim D.
    • December 15, 2006
    • 39
    Re: Question on timing chain gear alignment
    Assuming you have the engine on a stand, block the back end of the crank against the stand when you install the balancer so the pounding doesn't damage the thrust bearing surface.
    Hi John, the engine is still in car. I am just fixing a few oil leaks, they are my pet peeve, and while I'm at it I'll do fuel pump & water pump, hoses, ect...
