Welding Cast Iron - NCRS Discussion Boards
Welding Cast Iron
  • Ray C.
    • June 30, 2001
    • 1132
    Welding Cast Iron
    What would be the best electrode, or method, to use when welding cast iron. I would like the weld to rust if possible.
    Thanks for any information!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Welding Cast Iron
    Ray
    i had a cracked cast iron block welded in the water jacket and the welder used a nickle rod.
    • Mike M.
      • May 31, 1974
      • 8400
      Ray
      the cast iron part ought to be heated up in a furnace prior to welding with the nickle rod. if the part is valuable, i'd have an experienced welding shop with furnace capabilites do the welding..mike
      • Dick W.
        • 10483
        Cast iron is very tricky to weld without creating another crack. If you do not have expertise in cast welding, as Doc McQuack stated, take it to a welder that has an oven to heat (and cool properly) the item to be repaired.
        Dick Whittington
        • Kenneth B.
          • August 31, 1984
          • 2091
          Also one trick welders use to keep the crack from running is to drill a small hole at each end of the crack. That way the crack will not run when you weld it. Best left to a good weld shop that welds C.I.
          KEN
          • Chuck R.
            • April 30, 1999
            • 1434
            Nickle rod and lots of heat.
            We used to heat the cast until it was a dull red.
            Then perform the weld.
            Then keep the torch on the weld area slowly backing off on the heat to allow the metal to shrink gradually.
            Chuck
            • Dick W.
              • 10483
              KEN
              It will stop that crack, but will not stop the crack right beside the weld if pre-heating and cooling are not done properly.
              Dick Whittington
              • Ray C.
                • June 30, 2001
                • 1132
                Thanks to all!
                Ray
                Ray Carney
