1953 Cast Iron Powerglide - NCRS Discussion Boards
  • Steven N.
    • April 30, 2002
    • 214
    How does the corvette '53 powerglide differ from the '53 passenger car transmission. Are they the same main case. Can the passenger main case be used in a corvette.Thanks, Steven J.
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 1953 Cast Iron Powerglide
    I believe the main case is the same. The tailhousing is different, as is the tailshaft. Torque convertor maybe different, with more assembly bolts. Hopefully Roy will respond.
    • Mike M.
      • May 31, 1974
      • 8409
      53 vette PG uses an open drive shaft .53 Chevy pass car PG mates to a torque tube(chevy pass cars didn't go to open drive shafts till 1955). hence the tail shaft and tail shaft housings are totally differnet(53 vet vs 53 pass car).mike
      • Roy B.
        • February 1, 1975
        • 7044
        (YES!the same) also some people that had to changed the rear end of a 53-54 Corvette to a later 55 up Corvette having a open drive shaft can use a 55 up 6 banger PG.from a car complete .But you need a open drive shaft too.
