Frame repairs - NCRS Discussion Boards
Frame repairs
  • Martin T.
    • May 31, 2006
    • 196
    Frame repairs
    I am looking for either a C-2 front frame clip or someone who can repair mine. The frame was hit on the passenger's side and bent that frame rail and tweaked the horns. Any ideas on someone capable of repairing such damage would be appreciated.
  • Dick W.
    • 10483
    Re: Frame repairs
    Have someone check the frame to see if it is diamond shaped. If so, you will be better to replace the whole frame. If the damage is localized in the rf area, you can buy sections from Vette Products of Michigan www.vetteproducts.net
    Dick Whittington
    • Boyan B.
      • August 31, 1999
      • 189
      Re: Frame repairs
      Americas Finest Corvettes in Ramona California has a jig and can handle most about anything with a midyear frame. They advertise in the driveline.
      Boyan
      • Edward M.
        • November 1, 1985
        • 1916
        Re: Frame repairs
        Depending on how bad it is, you can have it pulled. I have a friend that has a 67 frame that was hit and diamond shaped. He got it pulled to within 4 mm of actual spec, which is well within the margin of error.
        • Wayne K.
          • December 1, 1999
          • 1030
          Need some education, what is diamond shaped mean?
          In reference to frame damage.
          • Edward M.
            • November 1, 1985
            • 1916
            Re: Frame repairs
            One side gets hit and shoves the entire frame rail back or forward. Frame is no longer square, it is now diamond shaped.
            • Dick W.
              • 10483
              Re: Frame repairs
              With a diamonded frame you have bent every crossmember and in my experience, is not worth the time to fix. You have lost a lot of the structural integrity with bends and stressed welds.
              Dick Whittington
              • Chuck S.
                • April 1, 1992
                • 4668
                Re: Frame repairs
                You could also say such a frame was "racked"...~vi: to become forced out of shape or out of plumb.
                The frame was formerly a rectangle, and then the blow changed it into a parallelogram without right angles.
                • Edward M.
                  • November 1, 1985
                  • 1916
                  Re: Frame repairs
                  Yep, my friend's frame had some crossmember weld cracks. Got re-welded as part of the repair. I guess it comes down to how bad is the frame diamonded (is that a word). Cost of repair was significantly less that a replacement frame.
                  • Bill M.
                    • April 1, 1977
                    • 1386
                    Re: Need some education, what is diamond shaped mean?
                    Originally posted by Wayne Kindschy (33314)
                    What is diamond shaped in reference to frame damage.
                    The way this is checked is to measure from RF to LR and compare that to LF to RR. The measurements will be the same if the frame is square. One will be shorter if the frame is diamond-shaped.
