Hate to stir up any controversy, but the fan that was and is on my late '65 L78, when I bought the car in 1988, [shown in thumbnail, hidden below the 2 auto-load pics] is only 17.04" in diameter (like that for a 396, rather than the 17.50" dia., which is on the GM drawing for the 3888366 '66-7 BB fan). Hope you can read these drawings at posted resolution. Notice last line on left bottom of '66-7 drawing reads "similar to 3872792". I take that to mean that (maybe ?) only the diameter has changed, indicated from the blade length of the '66-7 (5.93") being exactly 1/4" longer than that shown for the "792" dwg (5.68"). Other dimensions are essentially the same. All other stampings on my fan point to it being the '66-7 unit [FRONT, H, and 66, as well as W on backside of one spider].
Measurements taken in 2 stages; from edge of center hole to tip of blade, along centerline of rivets; then add 1/2 of dimension of center hole [2.377 to 2.380", painted, per dwg]; then multiply this radius by two for the diameter. (To Jack H.; all 5 blades were exactly same length).
Might add that my '65 car is so late that the next big block assembled in St. Louis was a 427, although the chances of its original fan surviving 23 years at the hands of various Bubbas is slim.
So .... what does the '66 TIM&JG say as to overall diameter; could my car have an early hybrid 3888366 fan with short blades like the 396 one ? And I'd like to shake the hand of any judge who can proclaim the difference between 17.0" and 17.5" overall dia., with the fan in place on the car
1966-7 427 fan from Noland's Vol 2 page 415
1965 L78 fan from Noland's Vol 2 page 286
