Build Sheet - NCRS Discussion Boards
Build Sheet
  • Martin N.
    • July 30, 2007
    • 594
    Build Sheet
    Gentlemen-
    What is the likelyhood of finding / seeing the build sheet on a 1974 convertible if one was to remove the 2 rear deck vent grilles and probe around with mirrors and a flash light? THANKS for any comments.
    MARTY
    Re: Build Sheet
    You might see something ESPECIALLY if you've got an articulating bore scope. But, you can reach the same location(s) by removing the gas door and folding down the rubber fuel overflow cup.
    If it's there, expect it to be COVERED with dust and be basically unreadable until you drop the gas tank. Then, it's a dice throw as to how legible what remains is.
    BTW, some have gotten lucky by looking between the speedo and tach for an extra copy of the original build sheet left there by those who installed the instrument cluster...
