CC - NCRS Discussion Boards
CC
  • John D.
    • December 1, 1979
    • 5507
    CC
    One thing I really like about this new forum is that you can readily see who is looking in to check up on your behavior and questions
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: CC
    [quote=John DeGregory (2855);353791]One thing I really like about this new forum is that you can readily see who is looking in to check up on your behavior and questions.
    how do you do that ?
    • John D.
      • December 1, 1979
      • 5507
      Re: CC
      [quote=Clem Zahrobsky (45134);353794]
      JD has inside connection. Actuallly when you first click on to the DB it lists on the bottom of the page who is looking in. Titles "What's going on". I tell you this is a first class forum. I am reluctant to change in my old age but I do like this format. The more you play around with it the more you learn what is actually available. JD
      • Chuck S.
        • April 1, 1992
        • 4668
        Re: CC
        If you're talking about the list of moderators, I'm convinced that is only an unchanging permanent LIST of the individuals that MAY be monitoring your behavior.
        The reason I say that is the list never changes; never fewer moderators, and never more. I KNOW that ALL those individuals aren't ALWAYS signed on here...Well, maybe Dickie if he doesn't have an active project in progress.
        • Terry R.
          • March 1, 2005
          • 359
          Re: CC
          Clem go to the top of the page,click on Quick links then Who's online and it will tell you more than you might want to know.
          • Clem Z.
            • January 1, 2006
            • 9427
            Re: CC
            [quote=Terry Robertson (43499);353820]
            thanks i see it now.
            • Mark L.
              • January 1, 1996
              • 121
              Re: CC
              JD,
              The same info is availble on the VH site. Select the 'forum' tab at the top of the page, then scroll down to the bottom. There is a list of on-line members.
              Try it, you might be surprised as to who is lurking
                Re: CC
                Chuck -
                Nope, not the moderator listing. Go up to the top of the page, click on "Quick Links", then scroll down to "Who's Online" and click on it, and it shows every member currently logged in and what they're viewing at the moment. Sneaky, huh?
                • John D.
                  • December 1, 1979
                  • 5507
                  Re: CC
                  Chuck -
                  To fully convince the whole DB the list of moderators is clearly spelled out. It's no secret. Listed right next to who is on line here.
                  The more you look at the DB the more you find out there is a lot of info for your entertainment. In stead of quickly going on line and reading all the intelligent questions look at what makes this forum tick. You will be amazed at what is available for you and how easy it is to use. Unless you don't know the left side of the car from the right side!!!
                  • John D.
                    • December 1, 1979
                    • 5507
                    Re: CC
                    Mark, I prefer not knowing thank you very much. Nice push rod. JD
                    • Joe C.
                      • August 31, 1999
                      • 4598
                      Re: CC
                      John,
                      Read your private Messages!
                      I just checked this morning and looks like "fearless leader" took care of it.
                      Sincerely and formally yours:
                      "Joesph" 32899
                      • John D.
                        • December 1, 1979
                        • 5507
                        Re: CC
                        A tad late though.
