67 L-68 Carb Jetting - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    I need to know the "factory" jet size for the tripower center carb 3660.
    Also what would be a recommendation for 5500 ft elevation. Also, are there any metering plate differences for high altitude.
    Thank you
    Tim
  • Larry M.
    • January 1, 1992
    • 2700
    Re: 67 L-68 Carb Jetting
    Tim:
    According to the 1967 Chevrolet Chassis Service Manual, the #R3660A center or primary carb jetting is #64 jets.
    The #R3659A secondary carbs jetting is shown as .076
    I don't know what to recommend to you at this time for the elevation changes you mentioned.
    A lot of Holley carb information is available on the Holley website in their Technical Information section. Check-out for additional carb settings and/or tuning recommendations.
    Larry
    • Clem Z.
      • January 1, 2006
      • 9427
      the area of the jets should be reduced 2% for every 1500 feet above sea level. a #64 jet has a .064 dia hole and the plates in the end carbs have a .076 dia hole. reduce the AREA of these by 6% and you should be in the ball park
