where to find matching numbers Q-Jet - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    Any input on where I can purchase a fully rebuilt, restored, bench and flow tested Rochester Q-jet carb that is correctly set up and is ready to bolt on, adjust and go.
    Also, I'd appreciate any input on the as-received condition for anyone that has purchased one; the restoration shop in Arizona I'm working with has indicated they have had to spend hours re-working supposedly fully restored carbs.
    I currently have a non-matching q-jet that needs a total overhaul and I'd like to find a good match.
    Thank you for you input.
    Don
  • Greg L.
    • March 1, 2006
    • 2291
    Re: where to find matching numbers Q-Jet
    There are various suppliers/rebuilders out there but your success will have a lot to do with which numbers you are looking for. Most of the battle is getting a correct numbers carb and then having it rebuilt. Expecting a carb restorer to have a rare, correct numbers carb rebuilt and ready to bolt on is possible but not probable.
      • 43297
      Don
      Don----
      You don't mention year and application. In this case, that's VERY important. Some Q-Jets are fairly easy to find and others are near-impossible.
      • Don W.
        • 492
        Joe,
        '69 427/390 hp auto; Q-Jet #: 7029204.
        Don
        • David K.
          • February 1, 1976
          • 592
          Don, post date range you need as well. If you are looking for matching numbers.
          • Don W.
            • 492
            I have a Nov 1969 build and I was told anything 6 months prior would be the max so May 1969 or later I think.....Don
              • 43297
              Joe,
              Don
              Don-----
              You're in luck because that's a carburetor that was used across the entire Chevrolet car-line in 1969. Besides Corvette, it was used on L-34 engines in Camaro, Chevelle, and Chevy II as well as passenger car L-36. I would go to the Driveline and see if you could find one.
              • Don W.
                • 492
                Joe,
                Any thoughts of putting the driveline online as a searchable ad data base?
                Don
                • Deane M.
                  • January 2, 2007
                  • 144
                  Don, sent you an e-mail with all the info for Custom Rebuilt Carburetors. Let me know if you have any questions.
